Note: [Trace] is used in the examples below. Ion Classic and Element Classic users will need to use {Trace}.
[Trace] works just as Track does, except it allows changes to be tracked backwards through the cue list, until it sees a move instruction. A trace will track into, but not beyond, a blocked instruction.
For a more detailed summary of Trace, see Using Trace
Following are some examples:
When a channel that is inactive (at zero or null) in the cue list receives an active level, if update trace is used, that channel will not trace the current setting into previous cues. To force that channel's new value to go backward in the cue list, [Trace] [Trace] can be entered.
